GenerateBlocks – Correct Button styling and creation workflow?
    Am using GP Premium and GenerateBlocks Pro 1.7.1.
    I am using Global Styles to configure my primary button: colours, hover etc. This is working, though the workflow for adding new buttons to a page seems bumpy. Here’s what I am doing:
    – Adding a new button to the page
    – Adding the .gbp-button–primary as a global style
    – Removing the default colours (background and hover) from the button
    These default colours are blue, and I need to remove them as they override the styles that I customised on the global button style.
    This is after I eventually worked out that the theme-level styles in the customise menu don’t apply to these buttons either.
    All in all, it feels pretty confusing & complicated so I’m wondering if my workflow is incorrect?
    Many thanks,
    Tom
    if you’re using GenerateBlocks Pro, then my preferred method is to work with patterns wherever possible:
    1. create your button
    1.1 add the global style and remove the local styles.
    2. save the button as a Local Pattern ( NOT Synced )
    Then add the pattern to the page instead of buttons.
