I’m trying to use a global style for SVG height in icon but have some problems with it. To just the dimensions of non-square SVG icons used in headlines, I want to use a global style ‘.gbc-svg-non-square-icon-correction’ class for headline blocks.1. While using Global Styles, I can select the icon. This is great, but the Height I enter there isn’t specific as there is some other css. How would you achieve that without using !important?
2. I noticed that the semicolon is missing in the admin area when I’m checking the generated css for example: {
height: 16px
Is this a bug? -
1. your CSS would need to be this specific:
.gbc-svg-non-square-icon-correction.gb-headline .gb-icon svg { height: auto; }
To do that, edit your
global style.
And choose the Manage Selector option and Add New.
In the field provided add:.gb-headline .gb-icon svg
and check the Compound Selector toggle. And click create.Now you should see the
selector class.2. Its not an error its just the way we compile our CSS, and a missing
from the last property in a rule is still valid. It may be something we can tweak so as not to cause any alarm 🙂 -
thanks. Works nicely.
Glad to be of help
