GenerateBlocks Pattern Library Fails to Load with Gutenburg Plugin Enabled
  • Hey team,
    I’m hitting an error where the Pattern Library (GenerateBlocks) refuses to load when the Gutenberg plugin is enabled. To be specific, if I go to “Edit Page > [GB] (Top Right) > Open Pattern Library”, the following happens: The pattern library model opens, I briefly see content layouts load in (but not the content), then I get a single error notification: “The editor has encountered an unexpected error.” [Copy Error].
    Here’s the error:
    SecurityError: Failed to read a named property 'document' from 'Window': Blocked a frame with origin "https://[REDACTED]" from accessing a cross-origin frame.
        at sl (https://[REDACTED]/wp-content/plugins/gutenberg/build/scripts/vendors/react-dom.min.js?ver=18.3.1:8:24289)
        at Gn (https://[REDACTED]/wp-content/plugins/gutenberg/build/scripts/vendors/react-dom.min.js?ver=18.3.1:8:42334)
        at https://[REDACTED]/wp-content/plugins/gutenberg/build/scripts/vendors/react-dom.min.js?ver=18.3.1:8:40630
        at Sl (https://[REDACTED]/wp-content/plugins/gutenberg/build/scripts/vendors/react-dom.min.js?ver=18.3.1:1:1741)
        at MessagePort.hl (https://[REDACTED]/wp-content/plugins/gutenberg/build/scripts/vendors/react-dom.min.js?ver=18.3.1:1:2131)
    I’ve tried disabling and re-enabling GB and GB Pro, no luck. The error points towards the Gutenberg plugin, so I tried disabling that; lo and behold, everything went back to normal.
    Any advice?
    Gutenberg is a plugin for testing purposes only; it will constantly have bugs and I am not surprised that it causes issues.
    I would suggest disablling it when using GB and GB Pro.
