GenerateBlocks Pro required even though I have GP Premium
  • Hello GeneratePress Support,
    I have a premium package/license, but when I try to import the Info site from the GeneratePress site library, it says GenerateBlocks Pro needs to be installed manually.
    Screenshot shows that GenerateBlocks is already installed, but the import button is disabled because GenerateBlocks Pro is missing.
    Can you please explain why this template requires GenerateBlocks Pro if I already have GP Premium? Is GenerateBlocks Pro included with my premium package, or do I need to purchase/install it separately?
    Thank you.
    It depends on which Starter Site you choose. Some Starter Sites require GenerateBlocks Pro because they use Pro-specific features available only in GenerateBlocks Pro.
    GP Premium is the base requirement for all Starter Sites. However, a small number of sites also rely on GenerateBlocks Pro functionality, which means GenerateBlocks Pro must be installed and activated for those sites to work correctly.
    Please note that purchasing GP Premium alone does not include GenerateBlocks Pro. You may want to take a look at the GP One Package if you want access to all products, including GenerateBlocks Pro.
    Hope that helps!
