GenerateBlocks Tab Stopped Working
  • For some reason, one of my GenerateBlocks tabs stopped working out of nowhere. In the beginning, I thought this might be due to the WordPress 6.2 update, but I downgraded back to 6.1.1, and the problem still persists.
    I have a page with the same exact tab system, and it works just fine. I can not find anything else to isolate test, so here I am. Do you have any clue what might be going wrong?
    Thank you!
    Can you try #1 here to debug first?
    https://docs.generatepress.com/article/debugging-tips/
  • Thank you for the reply. Yes, I found the source of the issue. It is the Code Snippets plugin, and more importantly, the issue is a shortcode PHP script I run through the plugin to display the items in the tabs.
    When I disable the PHP snippet, the tab works fine, but the weird thing is that error doesn’t affect the other tab I shared.
    I’ll shape the code below on the private information just in case there is something there that might interfere with the tabs.
  • When I disable the PHP snippet, the tab works fine, but the weird thing is that error doesn’t affect the other tab I shared.
    I’m not sure why this would be the case unfortunately.
    You will likely need to do some further debugging like strip everything clean and try to identify the issue that way.
