generateblocks types not supported after switch to version 2 blocks
  • Today, I tried to switch from version 1 to version 2 blocks. Unfortunately, after switching, I got error messages when trying to create loops, saying these blocks types are not supported by my Website. I tried this both on new pages and block templates. (And, in the end, I switched back to version 1…) Do you have any idea what could be wrong? (Here: both GenerateBlock Pro and GeneratePress Premium are installed with latest updates.)
    I never heard about this issue, can you provide an admin login and enable v2 so I can have a look at the issue?
  • Hi Ying,
    Thanks a lot for your response! I’ve set up the login for you
    Do you get the error messages when adding a Query Loop to a page? I wasn’t able to replicate the issue—I’ve created a draft page called Test Query Loop Page on your site, added a Query block, and saved it without any problems.
    Let us know if there’s anything we might’ve missed.
  • Thank you, Alvind! I figured out that the problem seems to be browser and/or OS specific. Everything works smoothly on a latest Windows machine indeed, and same with Firefox on an older MacOS (Catalina) as well. But the problems occurred on that Mac when using Safari (see screenshot). But that is a rather minor problem in the end (and I consider this issue as resolved).
    screeshot blocks v2 support problem
  • No problem, glad to know that!
