I have just updated from GenerateBlocks v1 to v2 and also purchased the Pro version.
I seem to be having a conflict the Grow for WP plugin – it keeps deactivating and has done ever since the upgrade to v2 and has been narrowed down to this.
Have you got any suggestions? Am happy to revert back to GenerateBlocks v1 if needed, just not sure how to do this.
Hope you can help!
Just to make sure that the issue happens if you disable all plugins except GB/ GB Pro 2.1.0 and the Grow for WP plugin?
Are you using a child theme?
Yes, I only have a few plugins and it seems to deactivate when GBP is now activated. I made the move from V1 to V2 in GB on Tuesday and then added GBP.
It’s why I wanted to rollback to Version 1 of GB… but I have found a workaround for the moment and deactivated the Grow for WP plugin and added the script to my header.
So it’s working fine now?
It seems to be OK now as I simply inserted the code – will close this now, thank you for your time.
