GenerateBlocks with Block Theme
    I want to ask if it is possible, to use the GenerateBlocks Plugin with a Block Theme like Rockbase?
    I haven’t tested it, but it should work.
    It works with twenty-twenty block themes.
  • So I have access to GenerateBlocks from this new editor, which is used to edit the block themes? And can I then simply put every section, pattern, etc. from WordPress into a GB container?
    Block themes come with the WP Site Editor.
    It is just another version of the block editor, and by default it will show you any blocks you have available including GenerateBlocks.
    If they do not show or work as expected then you would need to address that with the Theme developer as they may have “locked” down what the theme provides.
  • Hi David,
    thank you for this information.
  • You’re welcome
