creminski
Hi! I’m also having a problem with the “generatepress-content-width” plugin. It caused an error and can’t be displayed.
The site I work on is http://www.laportabergamo.it.
When I view an event (Modern Events Calendar plugin), the page goes from 1300 pixels to 700.
I’ve found several suggestions in the forum, but they don’t work.
Can you help me?
Thanks -
Can you try this solution?
https://generate.support/topic/third-new-wp-installation-generatepress-content-width/#post-182057 -
creminski
Thanks for the reply.
I’m not a code expert and I don’t know where to copy these lines.
Have a nice day.
Carlo -
Hi Carlo,
Please refer to this article for adding PHP:
https://docs.generatepress.com/article/adding-php/ -
creminski
Grazie, non funziona.
Ciao -
Please make sure you’ve added the code in the proper way.
How did you add the code?
creminski
Hi, as indicated, I installed the Code Snippet plugin and copied the code from the page https://generate.support/topic/third-new-wp-installation-generatepress-content-width/#post-182057
Thanks -
creminski
The error reported is
Unable to create snippet. Request failed with status code 500 -
This issue is best addressed by the plugin developer, as it appears to be caused by the plugin itself.
Alternatively, you can try using a different plugin, such as FluentSnippets or WPCode.
creminski
Thank you very much, Fluent snippet works.
The problem was caused by MEC modern events calendar.
Unfortunately, the plugin is no longer supported.Carlo
Glad to hear that! 🙂
