GeneratePress One startup
  • LeeAnnBillings
    I am upgrading to GeneratePress One. Are there any videos that walk through the startup process?
    I have found the page at the link below, but no video support.
    https://learn.generatepress.com/blocks/block-guide/getting-started-generateblocks/generateblocks-pro/generatecloud/?utm_source=chatgpt.com
    Are you looking to set up GenerateCloud specifically?
    If so, this video should help:
  • LeeAnnBillings
    Is there a way to copy sections into the Library site from existing websites, or do all the sections have to be rebuilt?
  • You can simply copy the section, paste it into your Library site, and save it as a Pattern. There’s no need to rebuild it from scratch.
  • LeeAnnBillings
    So I upload the GP Cloud plugin to each site I want to save a section from to the Library site. Do I save it as a pattern in the site of origin, create a key, and move it to the Library site? Or just copy each section and move it to a mock page for storage on the Library site?
    Does the GP Cloud enable copying of one section in a website to the Library site?
    The information says that the Library site has to be a public site. Does that mean no PW protection, like what would be put on a dev site? If a dev site is not published, but not PW protected, would that work as a Library site?
    I also find the name of the plugin confusing in that there is no “cloud”. From the name of the plugin, I was envisioning a GP Cloud similar to OneDrive (in the cloud) where sections could easily be saved and re-accessed, but there is no actual GP Cloud storage, correct?
    Thanks for clarifying.
  • You don’t need GenerateCloud on each site you’re copying from – it only needs to be installed on the Library site.
    Simply copy the section, then paste it into a new Local Pattern on the Library site. Assign it to a Collection and publish it. You don’t need a mock page or a key on the original site; the key is created on the Library site.
    GenerateCloud doesn’t copy the section for you. It makes the patterns stored on the Library site available to your other sites.
    A dev site can be used as the Library site, even without published pages, as long as it is publicly accessible and not behind site-wide password protection or maintenance mode.
    And yes, there is no GeneratePress-hosted storage. The patterns are stored on your Library site; “cloud” simply means your other sites can access them remotely.
    Hope that helps!
  • LeeAnnBillings
    Could you please clarify your responses:
    Your response: Simply copy the section, then paste it into a new Local Pattern on the Library site. Assign it to a Collection and publish it. You don’t need a mock page or a key on the original site; the key is created on the Library site.
    My question: Are you saying to create pages in the Library site and paste the copied sections into that page? For example, a page for similar sections like Hero sections, so different Hero section designs are stored on that page? And then save each one of the sections as a Pattern? A video to demonstrate your instructions would be helpful.
    Your response: A dev site can be used as the Library site, even without published pages, as long as it is publicly accessible and not behind site-wide password protection or maintenance mode.
    My question: I understand the need for No site-wide PW protection. Does the WP PW come into play at all?
  • Are you saying to create pages in the Library site and paste the copied sections into that page?
    No.
    What Alvind meant is you can create patterns on the library site and import the patterns into the site you are building.
    No, WP admin PW is not included in this case.
  • LeeAnnBillings
    Your answers are not clear.
    Alvind said the sections do not need to be remade in the Library. I am seeking clarification on how to move a pattern from an existing website to the Library. Could one of you create a video to visually show this process. Doesn’t a video tutorial already exist to walk people through how to use GP Cloud? If not, please make one to help clarify what you are saying.
  • On the site you want to copy the section from, click the three-dot menu for the section and select Copy:
    https://cln.sh/7g9wbddclczp4ysyHfbr
    Then on your Library site, go to GenerateBlocks > Local Patterns and create a new Pattern. Simply paste the copied section into the editor and save the Pattern.
    https://cln.sh/KSp8Qv3YjYL4XVqMLb9j
  • LeeAnnBillings
    Do all the Patterns have to be Public or is it enough to just have one landing page for the Library site Public and make all the Patterns Private?
  • No, the Pattern needs to be Published in order for it to be available for import on other sites.
  • LeeAnnBillings
    Can the site be PW protected with a WP PW, so all the patterns are not visible to the public?
  • Yes, that’s how it’s supposed to be. The Patterns won’t be visible to the public anyway if they live inside Local Patterns, not on public pages or posts.
  • LeeAnnBillings
    So Patterns are not visible to the public even when published because they are published as a Pattern?
    A WP PW log in is okay to have set up to protect access but a site-wide PW protection on the server end cannot be used, is that correct?
    Also, could you please explain how to set up the Patterns in collections?
    Do you have any examples of nomenclatures for Collections?
    Thank you for this additional information.
  • A WP PW log in is okay to have set up to protect access but a site-wide PW protection on the server end cannot be used, is that correct?
    Yes, correct.
    You can watch this video to learn how to build and use local patterns:
Viewing 16 posts - 1 through 16 (of 22 total)
  • The topic ‘GeneratePress One startup’ is closed to new replies.
