Getting rows to wrap properly
  • Hi
    I have a page that uses a lot of rows with 3 columns in it that works well on desktop view
    However, when I try to make it responsive and want it to go from 3 to 2 to 1 column, the 3 to 2 does not wrap properly and has a row of 2 and then a row of 1 and then a row of 2 and so on.
    I have done CSS to try and fix it or get it to work, so likely I have some errors in that. So I have now removed those to start fresh on this issue.
    Hoping you can help with the details provided to access below
    It appears that you’re using a different block plugin to build the grid. Unfortunately, we’re unable to provide support for issues related to third-party block plugins.
