Global class is not written to the CSS file
  • Hi team,
    Here in the blog I would like the entire container to be clickable, not only the button. To do this, I assigned the class .container-link to the loop item. When I check global classes, I can see that the class is being used there: https://ibb.co/sdgPFvns
    Unfortunately, it doesn’t work. The class is not written to the CSS file. As a result, it does not affect the container.
    I have already regenerated the CSS files in the settings. Unfortunately, this does not result in the class being written to the CSS file.
    What can I do?
    Thanks!!
  • Hi Stefanie,
    Can I check the backend?
  • Thanks for the offer.
    Suddenly it works! After I rearranged the global styles and saved the new order, it suddenly worked.
    So everything is OK!
  • Ha.. sounds good 🙂
