Global lement isn’t showing correct on one site
  • Hello, I work with GP pro and with the beta versions of GB and GB pro.
    I have created an element that is displayed on all pages as a hook “before footer” and refers to the contact page.
    It is displayed correctly on all pages, except on the photo page, which has the same structure as the others, where the element is deprived of the default height of 45vh, although it is the same element.
    Is this possibly a bug in the beta version or do you have a tip for me?
    Many thanks, Stephan and Iris
  • For your Info, I work always with the combination GP pro, GB pro, code-snippets, updraft, wp-armour, slim-seo and wpforms, no optimizing- or caching-plugin.
    I deactivated all plugins expect GP and GB and changed the theme to the parent, no changes to see in the element-behaviour.
    Thank you
    edit the footer and select the Section container block, and Duplicate it. Then delete the original.
    This will reset the CSS Classes on the blocks which will fix the issue.
  • Super David, this works!
    Thanks a lot!
  • Glad to hear that !
