Global Style not showing outside of editor
  • I know others have faced variations of this in other threads.
    I have recently set global styles which currently ar assigned in a local pattern and on one custom post type.
    When editing the post and applying the global style all is working well, the application of the global style causes display changes as expected on the back end.
    However if I view in the customiser or front end the global styles are not applied.
    I have tried the disable all other plugins/securities/caches etc without luck and am unsure what to try next
    Hoping you have the magic insight!
    Can you provide the site link? Use a browser inspector tool to check if the global styles class is applied to the specific element.
  • Yes it appears the global styles are absent on the front. They are definitely present in the editor
    I am attaching the link privately
  • Is there any error showing up when you save the edited page with global styles?
  • None that I can see
  • Do you have a staging site for us to log in and take a closer look at the issue?
  • I’m having this issue as well. Has it been resolved?
  • Hi @d,
    Could you open a new topic for your issue? We might need site information, and if you are the topic starter, you can provide access to the private information we might need.
  • Credentials provided for staging
    Is it ok for us to disable plugins on the stagings site ?
  • Yes go nuts! It’s only for debug purposes
  • I just checked one global style .brand-button, it seems working fine, the CSS its loading on the front end matches its global style:
    https://app.screencast.com/ICSs1qThIslSK
    Can you let me know which specific global style is not working?
  • It looks like the food_cm_container style is not working and food_nutirtional_inner_container
    You can see it here https://www.loom.com/share/16db4131a74a468c8509445c73d13651?sid=ede981db-49c5-4184-b4c3-ec90c3d318e5
  • The site I have left with just the essential GP / GB / Metabox plugins enabled.
    I am gonna ask Tom and the devs to take a look at this. As I done a few tests and could not get those styles to load on the front end , even though they are present in the admin.
    Will report back asap.
  • Ok thanks for the update.
    If you look at a fruit like blueberry you can see what I am trying to do (as it is styled but not with the global), I just want to use global styles so I can edit the template across the cpt more efficiently.
    I look forward to seeing what they find
Viewing 15 posts - 1 through 15 (of 15 total)
