themanduls
not really an issue but a bug I thought you might want to know about. I created multiple Global Styles. Recently, the one I use for Pinterest started showing a huge image in the editor: https://postimg.cc/w1pcqK23
The screenshot was taken on a laptop. However, when opened in admin panel or private window while logged out, it looks exactly as it should: https://postimg.cc/RWL1qPpd
I noticed that in order to fix it, I have to enter the global style in particular post where it’s used, resize the image to any other number, and then without saving it put it back to my desired value. Once I save that, it would show as it should.
This has happened with every single page where I use this global style.
I’m not sure I understand the issue, can you show me the page with the global style?
And what is the name of the global style?
themanduls
It happens on every single blog post, for example: https://themanduls.com/blog/diamond-beach-nusa-penida/
The name of the global style is pinterest-image.
It has width set to 300px. While the size is as desired when I view the images in private tab, or even in wordpress while logged in, the image is large when I go to editor (as in the screenshots I sent).
As if the sizing attribute didn’t work at all.Once I just retype the number 300 again in Global Style settings, it shows up correctly in the editor too.
if you edit the global style what sizing settings do you have set ? Can you share a screenshot of that
themanduls
Width is set to auto and height to 300px.
I can’t seem to replicate that. However, if you would like us to take a closer look, you can provide admin login access to your staging site if you have one set up.
