Google Ad before first h2
    please allow us one more question:
    How to insert a google ad before first h2 in blog posts and pages?
    1 Ad should be displayed only before first h2
    2 Would be great to be able to adjust distance to text and h2
    3 Any chance to exclude specific pages like imprint?
    Thank you!
    This plugin might do what you’re trying to achieve:
    https://wordpress.org/plugins/ad-inserter/
    thank you but no way! Each plugin is one security issue more.
    Is there no way to make it without plugin?
    If you need a code snippet then you can try this:
    add_filter('the_content', 'insert_custom_hook_before_first_h2');
    function insert_custom_hook_before_first_h2($content) {
        if ( is_single() && !is_admin() ) {
            ob_start();
            do_action('post_before_first_h2');
            $custom_hook = ob_get_clean();
            $pattern = '/<h2[^>]*>/i';
            $replacement = $custom_hook . '$0';
            $content = preg_replace($pattern, $replacement, $content, 1);
        return $content;
    this will insert a custom hook inside the Post / Page content before the H2.
    And you can access that hook in a GP Element by setting the Hook to Custom and in the field provided add: post_before_first_h2
    NOTE: this snippet uses the_content filter hook in WordPress, and so do many other plugins and functions, so theres no guarantee this will work as i cannot account for potential conflicts.
