GP One Service 2.0 Theme Home Page
    I am currently building a new theme in staging. How do I change the number of blog articles that appear on the GP One Service 2.0 Theme Home Page? In your site library, it displays only 3, whereas it’s displaying all of the blog posts I’ve created in the past staging
    Please let me know if you need further clarification.
    Thank you,
    Christian
    Edit the homepage and select the Query Loop block. You can then set the number of posts to display by adjusting the Posts Per Page field. See this screenshot for reference: https://cln.sh/0KlBmNZq
  • Hi Alvind,
    I have followed you instructions exactly and it’s still displaying a full page of posts. Is there a way to share a screenshot?
    Thank you,
    Christian
  • That shouldn’t be happening. To better assist you, could you provide temporary admin login access to your staging site so I can inspect the issue directly? Please use the Private Info section to share the credentials securely.
  • Hello – Please see the Private information.
  • Could you also provide the Site Authentication credentials as well? I’m unable to access the login page without them.
  • Please see private information
  • Okay, the issue is that all the posts being displayed in the loop are sticky posts. The Posts Per Page parameter does not limit sticky posts, they will always appear regardless of the set limit. So even if you set Posts Per Page to 3, if there are 10 sticky posts, all 10 will still be displayed.
  • Thanks so much. I made the correction. All is working nicely now.
  • Glad to hear that!
