GP One Upgrade and New Theme Staging
    I just purchased GP one and I am have created a staging site with my host. Can you please answer the following questions:
    1. Current GP Premium Theme: Do I need to update the license key for my current live site, which is still using GP Premium, while I continue to build out the new staging site?
    2. Staging Site: The staging site is currently a duplicate of the “live” GP Premium site. To change to a Services 2.0 theme, do I only need to add the additional Generate Blocks Pro Plugin, the new license key, and download the new theme to begin this new site build out?
    Please advise.
    Thank you,
    Christian
    1. Yes, you can do so before your GP Premium expires.
    2. We don’t recommend importing a template on an existing site, as your current customizer settings might conflict with the new template. But you can give it a try since it’s a staging site.
  • thank you Ying!
    So i have updated my new license key, added the generate blocks pro and removed my previous GP theme (Coach). I have gone to the site library located in appearance/generate press, but I don’t see the new GP one Services 2.0 theme listed.
    How do I go about downloading this?
    Note: I have purchased the GP annual subscription.
    Thank you,
    Christian
  • For the new sites built with v2 GB blocks, you will need to use v2 blocks.
    So go to generateblocks > settings, turn off v1 blocks, then go to the site library, scroll to the bottom, click refresh sites button, you should be able to see the new sites 🙂
    Let me know if this helps!
