ThisIsTrue
The last TWO updates to GP Premium triggers a WP alert, “Warning: This plugin has not been tested with your current version of WordPress.”
Yes, I know it still works. But it strikes me as inattentive or sloppy: you can’t increment the supported version number past 6.6? WP is at 6.7.2.
It creates support confusion among my clients, and I’m afraid I might be injured when my forehead hits my keyboard.
We’ve released a patch today, and it’s set to be compatible with WP 6.8
ThisIsTrue
Thanks, Ying. Hope they keep up with that in future releases.
ThisIsTrue
Yeah, except that the changelog doesn’t mention ANY changes done in 2.5.2, AND it still says it’s compatible up to v6.6. Sigh.
ThisIsTrue
It doesn’t:
https://snipboard.io/53M4ph.jpg
In short, the reported problem persists despite your assurance of a fix in the release yesterday.
Well, it does in GP’s change log.
It might not show up yet in WP.
ThisIsTrue
Bottom line: that’s a poor answer. You can’t pass the problem along? You’re saying I have to be satisfied with a Tier 1 response? Sorry, but “I dunno?” really isn’t acceptable when I’ve paid for support.
We knew the problem, it’s caused by aggressive WP cache, it takes time to show the actual message.
We’ve tried clear cache on our end multiple times, so it depends on when WP clear its cache.
Hope that’s clear!
ThisIsTrue
Yes, that’s clear AND helpful, thank you.
Indeed, without further updating it IS now showing compatibility, as well as showing 2.5.2’s changes. I’ve never seen such a lag previously, so it’s good to know of this possibility. I consider that a bug in WP!
I’m satisfied with the fix and will mark this as solved. Thanks again.
