GP Premium requires GeneratePress to be your active theme. Install now.
    I am getting an error/notice appear in wp-admin stating “GP Premium requires GeneratePress to be your active theme. Install now.”
    This has never appeared before. I have up to date plugins for all, and use a child theme for years – can you let me know why this is appearing and how to remove it?
    Kind regards,
    Will
    That notice appears only if GeneratePress is not the active theme. If you’re using GeneratePress but still seeing this message, there might be an issue.
    Can you check under Appearance > GeneratePress to see if all the premium modules are available?
  • Yes all premium modules are available and working as intended. The popup just randomly started appearing?
  • Can you try switching to the parent theme to test?
  • Ah yes thank you – that worked and found the root cause being the style.css of the child!
  • You are welcome   🙂
