Gravity forms conflict
  • Hello, do you have an issue with Gravity forms when it is embedded in popups? I just created a popup and used the gravity forms block widget. It displayed on the block editor but not on the front end when the pop up opens. Also, no matter what I do, the parent container in the popup will not let me set a background colour.
    Please advise.
    Can you link us to the page where we can see the issue?
    The form doesn’t display at all, or it displays without styles?
  • See private note for the link.
    Nothing loads for the form.
    Also, the background is transparent even though the background is set to #fff in the parent container. I even set all the nested containers to #fff and still no background colour.
    Let me know what you think.
  • The form has an inline style set to display:none, which means it’s hidden by its own style.
    https://app.screencast.com/cZv2021UyubCy
    In this case, you will need to check with the form plugin’s support, and ask them how to remove the inline style so it can show.
  • That’s weird becuase it works when it is not placed inside your overlay. It is only when it is placed inside a GB overlay that it exhibits that display:none; CSS…
    Why would that be? Sounds more like it is related to GB that Gravity forms itself.
  • Why would that be?
    It’s likely the form plugin has a condition that if the form is not inside the content area, hide it.
    So please check with the plugin support on how to remove that restriction.
  • I think it is a bug with the GForms block. Using a shortcode to place it fixed it. Weird.
