afuente
(just for mobile version)
on this site https://www.refugiodeestos.com, I want to display the footer containers side by side in pairs. Nevertheless the setup up of the cointainer, inside the grid, is set to 50%, it doesn´t work….
Could you maybe have a look? thanks
Angel -
Can you confirm this is the setting you’ve tried?
https://www.screencast.com/t/iHzVt6wT1VuIf so it should work: https://www.screencast.com/t/wRvU4npBg
afuente
Yes, it did what you say.
The problema was, that there were “too” much containers…
thanks you anyway
Angel -
No problem 🙂
