Grid Alignment
  • I have created a couple of blocks and each have a 50/50 grid element in them. In the 1st of the grid containers is some text. The second item in the grid is a GB Image. Each should occupy its 50% of the entire grid.
    I duplicated this grid and swapped image to be the 1st in the grid and text to be the second.
    However the 1 Block with its grid contents, does not align with the block below it. There is a small gap, so the image corners do not meet.
    Having exhausted about 200 layout combinations, please can you tell me how to make these grids alight with each other.
  • Simply select the Grid block, then remove the Column Gap value under Layout > Grid Layout settings.
    That should resolve the issue.
  • Thanks Alvind, just found it as you posted.
  • Glad to hear that! 🙂
