pesiiin
Hi, I need simple square layout. First row 4/3+3/4 background images, second row 3/4+4/3 images.All images are 1024×768 and 768×1024. What I need is same row height + images must be contain. All with some row+column gap. Can’t figure out right settings. (Not same height, or croped images). What is the right way to do this ? Happy with one row solution, so I can copy that to second row with reverse columns. Thanx a lot. Sample image.
Hi Pesiiin,
You can start with a GB 2-column Grid Block. Maybe give it a 60-40% width ratio.
Example: https://share.getcloudapp.com/qGuqExQg
Then add the images inside each Container.
For one image, set a specific Height.
For the other image, set the Height to 75%. Make the Container Block’s height which has this image to 100%. This is the 4/3 image (longer width).
Set the display of the Container Blocks to flex, and align them to center vertically.
pesiiin
Hi, are You talking about background images ? Because its the point…
No. Sorry, I meant to add GB Image Blocks inside the Container Block.
pesiiin
So, thats not a solution 😉
Did it not work? Can you share the link to where you have it built?
Or, do you need it to be a Background Image?
pesiiin
I need it to be background images, coz there will be some content overlay on hover like: here
it will require some custom CSS.
1. Add this CSS to your site:
.aspect-43 { aspect-ratio: 4/3; } .aspect-34 { aspect-ratio: 3/4; }
2. In the editor.
2.1 Add a Container Block
2.1.1 Set its Layout to Flex -> Row. And Align Items -> Center.3. Inside the Container add a new container.
3.1 in Layout > Flex Child set its Flex Grow to1
3.2 give it background image, and give it a small Sizing > Min-height eg. 60px. This is just so you can see it in the editor.
3.3 in Advanced > Additional CSS Class(es) add:aspect-43
4. Duplicate that container.
4.1 Change its background.
4.2 Change the Advanced > Additional CSS Class(es) to:aspect-34
