grid layout – on block hook
    We have a right side bar applied to all categories archive – but it was not showing – however it did showed to the author archive. I have two issues here:
    1. The right side bar is not showing on archive post.
    2. The right side bar in author archive there is an area that I cannot fixed it width – I think since the archive design was set to 2 column so it does affect the css of the right side bar.
    Pls refer to these screenshots:
    https://ibb.co/Q3dz06ZR
    https://ibb.co/5x6XHtLC
    Thank you so much for helping
  • Hello there.
    1. Right sidebar seems to be visible on the sample archive UTL you sent.
    2. The main content for the URL you sent us for the author archive is in two columns. Do you want that to be one column?
