Grid on mobile
    I have grid with two containers, each 50%.
    How can I select, which container sits on top on mobile view?
    I was looking for this earlier. You can try this:
    1. Select the mobile device options within the block
    2. In mobile options go to Block settings and set the grid item witdth to 100%. You need to keep settings at 50% on desktop with two containers.
    3.Scroll down a bit more in the block settings in mobile view to find the “Order” settings under Flex Child and under Flex.
    4. Enter 1 for Order for the block container you want on top on mobile. You can use 2, 3, 4, etc if you have additional items to order.
  • Thanks Zoltan!
    Here is the doc article for your reference: https://docs.generateblocks.com/article/layout-options-overview/#order
  • Hello Zoltan and Leo,
    Thanks, I managed it with this.
  • Glad to hear 🙂
