Search for: Grid order responsive afuente March 27, 2023 at 8:22 am Hello, i have a grid with 2 columns (50 – 50). One with an image the other one with text. In the responsive version, i want to display first the text (right colum). Is it possible? Thanks Angel David March 27, 2023 at 8:36 am Hi there, select the right hand column container, switch to Mobile view and in Layout -> Flex Child options set the Order to -1 this will move it before the other container. afuente March 27, 2023 at 8:53 am hi david, thanks again for your help 😉 David March 28, 2023 at 5:53 am You’re welcome Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic.
