Gutenberg block pattern won’t save
  • philipperoussel
    I use two Gutenberg blocks as patterns. For some reason, the modifications brought to their original templates cannot be saved anymore.
    Thanks for your help,
    Philippe
  • philipperoussel
    To be more specific, they are saved but do not appear with their new version on the frontend. I emptied the website’s cache and the browser’s history. No change. This occurs on any browser.
  • Hi Philippe,
    Are you editing the pattern in WP’s pattern editor or GB’s pattern editor?
    And do you have GB Pro on your site?
    I would recommend disabling all plugins to see if there’s a plugin conflict.
  • Hi Ying,
    I have GB, not GB Pro. How to tell the difference when using WP or GB pattern editor?
    I’ll do a check for plugin conflicts and let you know.
    Thanks,
    Philippe
  • Hi Philippe,
    You can distinguish them this way:
    WordPress Patterns are accessed from Appearance > Design, using WordPress’s native pattern editor interface.
    GB Patterns are available only if you have GB Pro installed and are managed directly within GenerateBlocks > Local Patterns.
    If you don’t have GB Pro active, then you’re definitely using the WordPress Pattern editor.
    Let us know how the plugin conflict testing goes!
  • philipperoussel
    And now… it works! I haven’t done a thing.
    Is there a plausible reason why the changes saved in Gutenberg patterns have taken 24 hours to show on the frontend?
  • If you do not have GB Pro, then you are using WP’s pattern, as GB’s pattern is a pro feature.
    Glad it is working now.
    Since the issue is related to WP’s feature, I’m not sure what the cause is, unfortunately!
    Maybe check with WP’s support.
  • philipperoussel
    All right. Thank you.
  • You are welcome   🙂
