H1 heading not showing for blogs listed on archive pages
    I have a blog on my site and on the main page of the blog I have set up the display manually using a query loop and displayed them in a grid with my own styling. In archive pages I thought I’d save time and set them up in the customizer. I have tried to do this but the h1 text/blog title name doesn’t appear. The featured image does, the excerpt does, but not the title. I don’t need the date to appear.
    I have tried going through the customizer settings to see where I’ve gone wrong and I can’t find a place in layout – blogs – archive (or any other place!) to add in ‘h1 heading’ or similar. I’d welcome some advice. I can of course create page pages, rather than archive pages, and do the same query loop set up for each category, but I would also like to know where I’m going wrong with my plan to set it up in the customizer.
    Thank you in advance for your help and time.
    Liz
    Can you check if there’s a layout element under Appearance> Elements that disables the content title on category archives?
  • Hi Ying,
    I have two elements that relate to those category/archive pages. They are only related to the Header (page hero, ‘after header’ hook – and it does disable the title in case important to know this) and Footer (Block, ‘generate-before-footer’ hook) as far as I know and shouldn’t impact the main body section.
    If you have more specific questions about the settings of those elements please let me know.
    Liz
  • Hi Liz,
    This CSS in the Customizer is responsible:
    .entry-title {
        display: none;
    Try removing that.
  • Thanks so much – yes – that is likely the issue. Just going to check what else it might be targeting and will make the changes.
  • Ok great, let us know how it goes.
