Hi, the header is not shown on the page above. The header should look like on this page: https://ecoassociazionerege.it/
instead the logo is moved etc.
I don’t know how to solve the problem… -
The first link provided goes to an error 404 page.
And the second link says that cannot be reached.
Please confirm.
Yes, the first link leads to a page with the 404 error but with the incorrect header.
The second link is wrong, the correct one is: https://ecoistitutorege.it
The page with the 404 error should have the header present in the second link… -
Edit the element you’re using for the header and try adding 404 Template under the Display Rules location.
How do I know what the header element is?
I have entered the login credentials in the appropriate box so you can see the situation more easily… -
if you view any page, and check in the Admin Bar > Elememnts menu you will see shortcut links to edit all elements on that page. See here:
https://app.screencast.com/fFQ6JGtnWu5yk
You will want to edit the Page Hero element I highlighted and include the 404 Template in the Display Rule Location .
OK. Thank you very much
You’re welcome
