George
I am using this method to include a background video in the header. Is it possible to be optimized somehow to avoid Cumulative Layout Shift? I am using Litespeed cache.
Hi George,
and if you disable litespeed ? Does the issue go away ?
As it looks like its causing the issue by deferring the CSS for the block and video. -
George
CLS is 0 with the litespeed cache off. I only have CSS minification ON when the cache plugin is ON. Activating
Load CSS Asynchronously
doesn’t fix anything. -
Have you spoken to Litespeed support ? As its looks like whatever its doing its messing with the CSS loading order.
George
Hey David, I managed to get some help from the Litespeed support forum, so I am closing this issue.
Thank you!
Glad to hear that George!
