Header Element
    In a previous topic you told me to do the following to add a link to the header.
    To add a link to your Header, I would recommend the following steps:
    1. Create a Block Element – Site Header. https://docs.generatepress.com/article/block-element-site-header/
    2. Add a Container Block. Reference: https://docs.generateblocks.com/article/container-overview/
    3. Add a link through the Toolbar.
    4. Add your Background Image: https://docs.generateblocks.com/article/backgrounds-options-overview/
    All this is correct and works, but even if I add the header tag (<header …. ) in the html it is not displayed.
    You can see it in the example that I give you privately. Thank you.
    I am not sure what you’re trying to achieve.
    Do you have an example of what you want to do ?
  • If I follow the instructions that you gave me in another topic and I have given you above, the html code is the following:
    <a class="gb-container gb-container-955d5844" href="https://www.example.com" rel="home" aria-label="cabecera"></a>
    All this even if I mark the block as header tag.
    In the example that I have given you privately you can see it.
    Therefore, it does not have the correct format, which is the following:
    <header class="site-header" id="masthead" aria-label="Sitio" itemtype="https://schema.org/WPHeader" itemscope="">
    <div class="inside-header">
    </div>
    </header>
    The first topic is this:
    https://generate.support/topic/link-to-home-in-header/
    Thank you !
  • You need to choose the hidden link instead of wrapper for the link type.
  • But that doesn’t solve the problem.
    The issue is that if I use a block in the header, I don’t get the header tag.
    Please, can you see the example that I have sent you privately?
    Thank you.
  • 1. Edit the Container and:
    1.1 remove the container link.
    1.2 set the Layout > Position to Relative
    2. inside the Container add Button with the Link and the Attributes you require.
    2.1 Give the Button an Advanced > Additional CSS Class of: container-link
    Once thats done let me know, and we can provide some CSS to make the link fill the Container.
    But what button?
    I just wanted to be able to link the background of the header image to the home page.
    Can you please read this topic?
    What happens is that although marking that it is a header tag, it is not shown as such, but one more block.
    Like this, with your <header and itemprop…etc
    </div>
    </header>
    With GB is ike this:
    Thanks.
  • The issue is that if I use a block in the header, I don’t get the header tag.
    Have you tried this? In order to have the header tag, you need to do this:
  • Sorry, but I choose hidden link and the problem is the same.
    Can you see the example I sent you privately?
    Thanks.
    This is what I’m seeing from my end: https://share.getcloudapp.com/wbuLnQoA
    It’s already a <header>. Is that what you’re going for or something else?
  • Ok, thanks !
  • You’re welcome!
