1job.ai
I was wondering if there is a way to change the menu alignment .
I want to achieve something like the attached image below.
It would b great if you can help me with this.
Thank you -
what happens on mobile?
ie. where would the login and register buttons go.
Would they show inside the mobile header or inside the navigation menu ? -
1job.ai
Hi David,
I have attached mobile menu design below, also login and register button has external links.Thanks
OK. We can do the desktop first.
And then revisit the mobile.
But first you have this CSS on your site which is affecting the menu list:ol, ul { margin: 0 0 1.5em 1.5em !important; }Can you replace that witH:
#page ol,#page ul { margin: 0 0 1.5em 1.5em; }Then it will only affect lists in the page content. Not the navigation.
1. Add this CSS to your site:
@media(min-width: 769px) { .main-navigation, .main-navigation .main-nav { flex: 1; } .main-navigation .main-nav .pushright { margin-left: auto; } }`
2. In Appearance > Menus give the Register <a href=”https://docs.generatepress.com/article/using-the-wordpress-menu-builder/#custom-classes”>menu item a CSS Class</a> of
pushright3. In Customizer > Layout > Primary Navigation and disable the Nav Search.
Once thats done. We can look at the mobile menu.
1job.ai
Awesome, Completed the above steps. We can look into mobile now,
Thank you -
OK, to add the button into the Mobile header.
1. Create a new Block Element in Appearance > Elements:
https://docs.generatepress.com/article/block-element-hook/
2. Set the Hook to
menu_bar_itemsthis hook is positioned to the side of the menu / hambuerger menu.
3. Set the Display Rules > Location to
Entire Site4. Add your button to the element, and in Advanced > Additional CSS Classes add:
hide-on-desktop hide-on-mobileAfter that can you disable the Off Canvas Panel in Customizer > Layout > Off Canvas so I can look at the mobile menu item styles
