Header not rendered
    I’m having a problem with my website header and wonder if you can help. My site is https://johnglostersmith.org
    I’ve just changed the header and it is not rendering on the Home page, although it does show on other pages.
    I did a plugin deactivate/reactive test and the GeneratePress plugin and its associated other plugins proved to be the one plugin(s) where the header did not display. When GP was deactivated, the header showed up as it should.
    The header is the same sized image as before but is a png file, not a webp.
    I now have it with the GP plugin activated so that you can see what’s happening.
    I use WP Rocket to speed up delivery. I obviously also tested that.
    I’m baffled!
    Best regards,
    John
    John Gloster-Smith
  • Hi John,
    The issue appears to be related to caching. When I view your site while bypassing the WP Rocket cache, the header renders as expected:
    https://cln.sh/Y467q4W2v56vxGSCWGwQ
    Try purging the WP Rocket cache. That should resolve the issue.
