markpropeller
Hi, I am having some problems with my header. Previously the mobile header was hidden on desktop. that option is still selected, but i can see it there. Also, previously the echo fest logo was much bigger and offset half in the blue bar and half over the photo. This morning I have come in and both these problems happened with the header.
https://wordpress-1167888-6157380.cloudwaysapps.com/
Any help would be much appreciated.
Hi Mark,
Do you mean this option?
https://cln.sh/6yZF9VRf8yTZy2dBKDDMIf so, it should not display on desktop when configured correctly. If possible, could you provide a temporary admin login so we can take a closer look?
Regarding the Echo Fest logo, try selecting the logo Image block, remove the width value, and set the top margin to around -100px so it offsets upward.
markpropeller
Hi Alvind,
Yes, I have that selected, it just seems to have stopped working.
Same with the logo, i had done it through positioning -100px and then it stopped working. I tried using margin instead of position and it hasn’t helped.
I have provided a temporary login on the private part of this chat.
The Grid block is supposed to be nested in the site header block, right?
However, the Grid block is dragged out of the site header block, and it does not have the hide on option enabled:
https://app.screencast.com/eICUQG9Nb6EmKTry dragging the Grid block back into the site header block.
As for the logo, is it supposed to be in the 2nd container of the Grid? If so, there is nothing, no image is added:
https://app.screencast.com/gO0xiFqLoFprx -
markpropeller
that’s fixed the mobile header, thanks.
The 2nd container is supposed to be empty – i’m just using it as a spacer. I want the image to overlap the blue and the hero image on the page, so I’m trying to pull it up from the block below.
In the editor it looks the right size, but when i open up the screen it is always much smaller, and I’m not sure why. this was working and was the right size before.
Can i attach an image here to show what i mean?
You can upload the screenshot to your site’s media library and share the link with us.
