pekingdentist
I have a headline block which sometimes is divided on two rows. The headline is dynamic and shows the post category using the list of terms function. The headline has a 1px border.
When there is a long category name, and especially on mobile, the headline is split to two rows (which I want) but the block and border becomes full width instead of having the width of the text. I think you’ll understand the issue from the image. I’ve tried all settings I can think of, and I’ve also spent over 2 hours with claude.
Any input on this would be appreciated! Thanks.
image: https://postimg.cc/KkTQ46x2
To make the border wrap the text instead of stretching full width, select your Headline block, then in the right sidebar go to Layout → Display and change it from Block to Inline-block. (Screenshot)
This will force the border to hug the text even when it wraps onto two rows.
pekingdentist
Thanks Chaz!
Changing the headline to inline block does not help unfortunately. Any idea if I could have done something to hinder it? I read somewhere that grids can force full width. I have attached an image of the list view.
Try wrapping the headline block in a container, then apply the border style and set the container’s display property to inline-block instead.
pekingdentist
Awesome, thank you very much Alvind!
pekingdentist
Sorry, I thought it worked but I still get this:
screenshot: https://postimg.cc/ZBb3QGBX
The black border is the container that holds the headline block. Both of them are set to inline-block. I tried the other display settings for the container as well.
Could you please share the page URL so we can take a closer look?
pekingdentist
Do you see it if I put it in the private information field?
Could you please remove the additional Container that Alvind suggested, as that should not be required and is adding an extra border? Once removed, we can review
pekingdentist
thats actually not possible with just HTML and CSS and maintain responsive behaviour.
But you can do something similar where the border wraps each line of text, usingbox-decoration-break: clone;.See the example here:
https://developer.mozilla.org/en-US/docs/Web/CSS/box-decoration-break
To add that property does require some custom CSS as its not in GenerteBlocks.
So try this:
1. select the Headline block with the term list
2. remove the padding and borders
3. give it a CSS Class of:decoration
4. Add this CSS to your site..decoration .post-term-item a { line-height: 2; padding-inline: 4px; border: 1px solid; -webkit-box-decoration-break: clone; box-decoration-break: clone; } -
pekingdentist
Thank you David, appreciate it!
You’re welcome
