Headline Top Border Width
  • So, I had an idea to use the top border as an overline. This should solve the problem of only having 1 top line if the headline was wrapped in mobile. What are the settings to make it so the top border spans only the length of the headline and not the entire container?
    Any chance you can link us to the page in question?
  • Hi Leo,
    Unfortunately the page is still in draft mode. Before the large update, there was a setting to force the headline inline to as wide as the text. Is that still available?
  • I believe the Inline Block, Inline Flex, and Inline would be what you are looking for:
    https://docs.generateblocks.com/article/layout-options-overview/#display
  • Thanks Leo! Inline BLock worked. But here is an odd thing. It did not work within all containers. Not sure why but with identical blocks, most worked but some did not. Have to copy and paste the parent container settings to make this work. Odd. It works, let’s leave it at that.
    Thanks again!
  • No problem 🙂
