Headline vs. Gutenberg paragraph block
  • Question
    Is there any reason/disadvantage for not using the Generate Blocks headline-paragraph block instead of the standard Gutenberg paragraph block for normal text paragraphs?
    TNX
    The default paragraph block is much simpler than the GB headline block with <p> tag.
    It does not have any CSS classes or additional HTML as the GB headline block does.
    If you don’t need to modify its style, just pure text, then go with the default paragraph block.
  • TNX Ying, understood
  • You are welcome   🙂
