arreaga88
Hello GeneratePress team,
I’m currently using GeneratePress Pro and GenerateBlocks Pro, specifically the Overlay Panels (Mega Menu) feature.
I’ve set up two mega menus:
1- One for “About us”, which I want to appear exactly below the “About us” menu item, perfectly aligned with it (not centered or offset).
2- Another for “Solutions”, which I want to appear centered below the “Solutions” menu item (since that mega menu is wider).
I’m using desktop-only Overlay Panels for these, and they are hidden on tablet and mobile using CSS, where I use a different menu layout.
Could you please tell me the correct way (or CSS selectors / positioning method) to make:
1- The “About us” mega menu appear exactly under the “About us” menu item.
2- The “Solutions” mega menu appear centered under “Solutions.”Here are my setup details:
Theme: GeneratePress Pro
Builder: GenerateBlocks Pro
Header: Built with a GP “Element” (Site Header > Navigation > Menu Container > Menu > Menu Item).
Mega menus: Created in GenerateBlocks → Overlay Panels.
Position to parent currently points to the navigation container (.gb-site-header), but I’d like to attach each panel directly to its specific menu item.Thank you so much for your help — I just need the right selector or setting so each mega menu aligns properly under its corresponding menu item in desktop view.
1.1 Set the overlay panel’s Position to Parent to
.menu-item-462instead of.gb-site-header. The.menu-item-462is the about us menu item’s default class.You can also add a custom class to the menu item via appearance > menus, eg.
about, so you can set the Position to Parent to.about.1.2 Set the overlay panel’s Placement to Bottom left.
2.1 Same as 1.1, but you can use another custom class eg.
.solutionsfor the solution menu item.2.2 Set the overlay panel’s Placement to Bottom center.
