Help Reset Modules: Website is a mess
    I was playing in the module area figuring out what everything was and decided to do the reset.
    Now my website is a mess. I activated everything back in the module area, but it’s still a mess.
    None of the colors are there.
    I had to turn all the elements back to all users. They all said none.
    Is there a way to get my site design back without redoing everything?
    The homepage is missing it’s blocks and verbiage, the home page is in the wrong format. The menu is in the wrong place etc etc.
    Thank you.
    Janet
    Not exactly sure if I understand the question but it’s not possible to revert a reset if that’s what you are asking.
    I think the only way to revert the change is to restore a backup from your hosting service.
    Hope this helps 🙂
  • So by doing a reset I basically got rid of my Library starter site?
  • I found a do around in case someone else asks.
    I went back into the site library. Didn’t remove the old site and put the same site library them or whatever they are called, back into the site.
    I have duplicates in many areas, but my site is back with alot less work to fix.
    No – The Reset function will only reset the customizer settings as suggested in the description.
    I believe restoring a backup would be an easier solution so you won’t have to remove the duplicate but glad you found a workaround solution that works for you.
  • The topic ‘Help Reset Modules: Website is a mess’ is closed to new replies.
