Help with design (multiple SVG backround images)
    I need to recreate this design with GB pro and GP pro, and I’d really appreciate an input on how to best approach it:
    https://postimg.cc/kB2CpdZN
    As you can see, there are multiple SVG elements in the background. The problem is that I want them to behave responsively, so I don’t think that using a single image is a viable option. The page will fill the viewport (100vh). The background is a radial gradient.
    Thanks a lot!
    the simplest method would be to use the Advanced Background option and use different images for the Desktop, Tablet and Mobile. Set them to a pseudo background.
    For the Radial Gradient you would need some CSS.
    Let me know if you need assistance with that.
  • Thanks David!
    One last question: is it possible to individually target different “background elements” (pseudo backgrounds belonging to the same container) with effects and with custom css? I don’t see the possibility to add a class to specific background images… This would be helpful, for example, to individually rotate the different elements (with different angles).
  • If you have a different pseudo background for each device size: Desktop, Tablet and Mobile.
    Then you can create a separate Effect for each specific device size and target the background image.
  • I see, thanks for your support!
    I’d love to see the ability to add custom css classes to specific advanced backgrounds, in the future.
  • Marked as resolved
  • CSS Classes for advanced backgrounds aren’t actually possible.
    As there is only ever one HTML Element eg. the <div class="gb-container"> to which the CSS background is applied.
    Glad to hear it worked 🙂
