Help With Footer
  • I feel bad because soon as you guys helped me with my footer from my last topic, I got rejected from an ad display network so I need to change it unfortunately. I apologize!
    So in the first link in the private information, I would like the footer to look similar to this. But would like 4 columns instead of 3. My site is in the 2nd link in the private information.
    So to approach this, would I add a Columns block and set it to 4?
  • So I worked on it more and right now if you go to my site I feel like I almost have it down. The only thing is the 4 columns are spread too far apart. I was hoping to get the side from the left and the right in the center more. and also the gap between the 4 columns smaller so everything is closer.
    I added another link for an example in the private information. They look like they are using 4 columns as well and all 4 are closer together. Looking to achieve something similar
    Also on mobile it looks a little different. Can we have everything to the left on mobile. If you take a look at the 2nd example on mobile, all the items in the footer is to the left side it looks like
    You’ll need to make a small adjustment to your current layout.
    First, wrap the Grid block (gb-element-cbcbc367) inside a parent Container. Then set the parent Container’s background color to match the current background color of the Grid block.
    Next, select the Grid block and apply these settings:
    Max Width: 1200px
    Margin Left: auto
    Margin Right: auto
    Then switch to Mobile view and, with the same Grid block selected, apply the following settings:
    Justify Items: Start
    Margin Left: 30px
  • Thank you so much! This looks like it has fixed everything! This topic has been resolved!
  • You’re welcome!
