blarney27
Hello. ANy chance you know why my Hero container struggles to load? The websites page color loads, and then the hero container has a gradient and a background color that snap in to place, then the image. It’s really delayed and only happens on a mobile device. Thanks!
Your image is 131kb, it’s kind of large, can you try reducing its size?
And it’s being lazy-loaded, some plugin might be doing that.
Try adding
loading
attribute to the image, and set the value toeager
to see if that can override the lazy load.
https://app.screencast.com/m5ADGgRMrgjCl -
blarney27
I thought it was being lazy loaded but I turned it off…at least I thought I did. When I reduce the size it pushes the image to the left, how do I reduce the image to lets say 80% and keep the image in the middle?
I meant to reduce the image file size not the image render size.
There are tools online to compress png files.
blarney27
Ok. It’s reduced as much as possible. Without he image, it still has this weird delay with the background gradient. I did the the “loading eager” thing, didn’t really help. Before I deactivate the cache plugin, any other suggestions/ideas?
blarney27
I got it worked out….thank you for your help.
