Anonymous
I want to Hide the “freebies” category from appearing on my shop page. But still conserve this page category separately. How to do this?thanks for your assistance
Try this CSS, it hides the 4th category in the woocoomerce category block, but if you add new categories, the order might change, so make sure you update the CSS if that happens:
.woocommerce-shop ul.woo-cat-nav li:nth-child(4) { display: none; }
And do you want the freebies products hidden on your shop page as well? or that’s fine?
Anonymous
hi Ling,
after adding it appears as the freebie is hidden however, when i click on any another category for ex: coloring pages, the freebies appears.for reference: I would still like to keep this page:
https://mysite.com/product-category/freebies/Just not have freebies visible in the shop
Thanks again
https://mysite.com/product-category/freebies/Yes, it’s showing.
https://app.screencast.com/h8siBeg2s1NArJust not have freebies visible in the shop
Right, the code should only hide it on the shop page.
Anonymous
Hi Ling,
Sorry I mean to remove it anywhere on the shop AND other categories. It is still visible there for other categories ex: all-products/ coloring-pages-category/ etc.. and the rest. I would like it not to show up there. -
Try replacing Ying’s CSS above with this one instead:
body.archive ul.woo-cat-nav li:nth-child(4) { display: none; }
Anonymous
Thanks very much. How would re-ogranizing the order (of the categories on the shop page) work going forward. I checked under customize for a woocommerce menu but didn’t find anything that would help me reorder.
I’m not sure if the woo category block allows reordering. you’d check with Woocommerce’s support.
