Rafiozoo
Hi there
I use Page Hero block built with GenerateBlocks Pro (v. 2.3)
My categories are hierarchical (core WP posts).
I’d like to alter my post meta category links{{term_list link:term|tax:category}}
Child, Grandparent, Parent (if they are all checked on)
or
Child (if only the most specific category is selected)to:
Grandparent > Parent > ChildPlease help
GB does not have this option to order the term list, unfortunately!
Rafiozoo
No filter can be applied?
That’s currently not possible — there isn’t a filter available that can be used for that use case, unfortunately.
Rafiozoo
OK, I understand.
I’d like to share a solution that we have figured out with ChatGPT 😉
It works in regular GeneratePress theme / GP Premium (archives, search results, single posts), not in GenerateBlocks./** * Filter post categories output to display hierarchy (Parent > Child), * removing standalone parents if they already appear in a child chain. * Wrap each chain in <span class="chain">…</span>. */ add_filter( 'the_category', function( $thelist, $separator = ', ', $parents = '' ) { global $post; // Do nothing in backend if ( is_admin() ) { return $thelist; } if ( ! $post ) { return $thelist; } $categories = get_the_category( $post->ID ); if ( empty( $categories ) || is_wp_error( $categories ) ) { return $thelist; } // Collect all parent IDs used in any chain $parents_in_chains = []; // Build all category chains $chains = []; foreach ( $categories as $cat ) { $chain = []; $current = $cat; while ( $current ) { $chain[] = $current; $current = $current->parent ? get_category( $current->parent ) : null; } $chain = array_reverse( $chain ); $chains[] = $chain; // Save parent IDs (exclude the leaf itself) foreach ( array_slice( $chain, 0, -1 ) as $parent_term ) { $parents_in_chains[] = $parent_term->term_id; } } $output = []; foreach ( $chains as $chain ) { $leaf = end( $chain ); // Skip standalone parents if they already appear in another chain if ( in_array( $leaf->term_id, $parents_in_chains, true ) ) { continue; } // Convert to linked names $names = array_map( function( $term ) { return sprintf( '<a href="%s" rel="category tag">%s</a>', esc_url( get_category_link( $term->term_id ) ), esc_html( $term->name ) ); }, $chain ); // Wrap in span $output[] = '<span class="chain">' . implode( ' > ', $names ) . '</span>'; } return implode( $separator, $output ); }, 10, 3 ); -
Thanks for sharing 🙂
