Highlighting a link when it is on the current page
    I have a mini “category menu” on some of my pages, which is inserted as a Pattern.
    I would like to highlight the link when it matches the current page that I am in.
    Can this be done by CSS only? Have done a lot of searching, but I’m mainly seeing solutions on navigation menu items.
    Thanks in advance!
    Unfortunately not. It works for menu items as WordPress adds unique classes current-menu-item current_page_item:
    https://www.screencast.com/t/YVXim2EGb
    And WP does not add a unique class to the activated link, unfortunately.
    Sorry about that!
  • Thanks for the reply. May I know if there is a different way to do it?
  • Not I’m aware of. This is the default WordPress behavior so not something the theme can control.
    You would need a custom JavaScript solution to add a unique class to the activated link. If it’s required for your build then you can consider hiring a developer using a service like Codeable suggested at the bottom of this page: https://generate.support/what-support-includes/
