homepage does not change
  • hi GP,
    In Customizer, Homepage-settings I chose a new homepage (on gerlos90.nl: “Geweldig Gerlos”
    But when I open the site gerlos90.nl, it stills opens on the old homepage, and in the list of alle pages, the old page is still marked as ‘Homepage’.
    What do I wrong? Your help is highly appreciated.
    Caj
    if you go to Dashboard > Settings > General, try changing the home page there.
  • Thanks David. That worked,
    But why is it that the customizer didn’t do the trick? Are these two bothering each other?
    Have a nice day,
    Caj
  • Hi Caj,
    The setting in Settings > Reading should be the same as the one from the Customizer.
    When you saved, was the button set to publish or draft? It could also have been a caching issue.
