Homepage images size
    I imported volume theme from the library. Since then, I have been publishing articles. I found out that in the homepage, the images of the new articles seem to display bigger than the images of the standard imported theme, as shown in the image below:
    Any ideia on how can i put the images to display like in the standard volume theme?
    Thank you.
    The best solution would be to crop your featured image to the desired size before adding it:
    https://wordpress.org/documentation/article/edit-media/
