Hook-Element giving error after image size variant php
  • techbackend04
    After I add the below code in the functions.php of child theme NOT to create image variants.
    // Remove all image sizes and srcset on upload
    function remove_all_image_sizes() {
    return array();
    add_filter(‘intermediate_image_sizes’, ‘remove_all_image_sizes’);
    // Remove additional image sizes on upload
    function remove_additional_image_sizes() {
    remove_image_size(‘thumbnail’);
    remove_image_size(‘medium’);
    remove_image_size(‘medium_large’);
    remove_image_size(‘large’);
    // remove_image_size(‘custom-size’); // Uncomment and replace ‘custom-size’ with your custom size name if needed
    add_action(‘init’, ‘remove_additional_image_sizes’);
    I am not able to open any Elements. It sends the below error. After I remove the above image size code, the elements works fine.
    Error Details
    An error of type E_ERROR was caused in line 1760 of the file /wp-content/plugins/gp-premium/elements/class-block-elements.php. Error message: Uncaught TypeError: array_merge(): Argument #1 must be of type array, null given in /wp-content/plugins/gp-premium/elements/class-block-elements.php:1760
    Stack trace:
    #0 /wp-content/plugins/gp-premium/elements/class-block-elements.php(1760): array_merge()
    #1 /wp-content/plugins/gp-premium/elements/class-block-elements.php(154): GeneratePress_Block_Elements->get_image_sizes()
    #2 /wp-includes/class-wp-hook.php(324): GeneratePress_Block_Elements->enqueue_assets()
    #3 /wp-includes/class-wp-hook.php(348): WP_Hook->apply_filters()
    #4 /wp-includes/plugin.php(517): WP_Hook->do_action()
    #5 /wp-admin/edit-form-blocks.php(272): do_action()
    #6 /wp-admin/post.php(187): require(‘/home/techback/…’)
    #7 {main}
    thrown
    Appreciate your support to resolve.
    Disable the code first, then check each of the elements if any non-full-size image size is being selected for image blocks.
    As with the code, you only have full-size images available, if you choose other sizes for the images, it will cause errors.
  • techbackend04
    I have only 2 elements, one for the login icon hook and another one for footer.
    https://imgur.com/vioEMhZ
    https://imgur.com/7M3ehHf
    Even when I change these elements to draft, still get this error. Also with the image size code, I am unable to create new elements. It just gives the error before going to the draft page.
    If I remove the code, all element and new element creation works.
    In the 2 elements, I do not have any images, just icon svg’s.
    Appreciate your dedicate support.
    The error suggests that the function is expecting an array. We can try returning an array with an empty string instead of an empty array. Try this code:
    function remove_all_image_sizes( $default ) {
        $default = array('');
        return $default;
    add_filter('intermediate_image_sizes', 'remove_all_image_sizes');
        remove_image_size('thumbnail');
        remove_image_size('medium');
        remove_image_size('medium_large');
        remove_image_size('large');
        // remove_image_size('custom-size'); // Uncomment and replace 'custom-size' with your custom size name if needed
    add_action('init', 'remove_additional_image_sizes');
  • techbackend04
    Awesome Alvind.
    The above code works fine.
    Thanks for your support.
    Good Luck.
  • No problem!
