Hook Elements are not showing
  • Hi
    when I open / try to edit a hook element, it only shows the element title (top) and publishing panel (right), but the area to edit the code is not visible any more, here’s a screenshot.
    No other plugins are activated. You find an admin-auto-login-link in private notes, maybe you can take a look what’s going on there? Feel free to do whatever is required to help troubleshooting the issue 🙏 it’s just a testing site 😉
    Kind regards
    Sascha
  • Ehi there,
    I was opening a new ticket but then I saw this one. Me too having the same problem, thanks!
    its a known issue that affects some users after updating to latest version of WP.
    It’s related to some “bad” data that gets written into the user profile , which results in certain admin CSS not loading.
    We will be adding some a patch in the next GPP update to remedy this.
    In the meantime you have a couple of options, either:
    a) delete your existing admin user and register a new one.
    OR
    b) use the following PHP snippet to fix it:
    add_action( 'admin_head', function() {
    	echo '<style>#generate_premium_elements.closed .inside {display: block;}</style>';
  • Thanks, the snippet solved it 🙂
  • Glad to hear that!
  • The snippet solved the issue for me as well! The issue rose out of nowhere, it was not related to any new plugin install or core update.
  • Glad to hear that !
  • Want also to say thank you, solved the problem for me aswell
  • Awesome 🙂
  • Same issue for me-
    Sascha, Benson, leveque- would you happen to be running Learndash? I’m wondering if that’s where the ‘bad’ data is coming from, as it writes to the user data.
    Edit- neglected to mention that the snippet worked great. Thanks David, Ying!
    Also- I just noticed that the issue was the classic editor plugin, possibly? I have that, so that definitely checks out with others who have commented here…
    Cheers
  • It works also for me, thank you David 😉
  • @michaelbgood
    Nope, not running Learndash
  • Hurray, worked for me too! Thanks
  • Hello
    I have the same problem: I don’t can edit my element “wp_head”.
    And it’s not possible for me, to create a new element with the type “hook, layout and header”.
    But I can create and edit elements from type “block”
    I copied the code form obove into the function.php:
    But it doesn’t fix the problem.
    Can I be a problem with the editor. I_m using the classic editor and the siteorigen page builder to create posts and sites.
    Do you have any idea? If you need my login-dates, please let me know.
    Thanx
    Heinz
    PS.
    I’m using a childtheme from “GeneratePressVersion: 3.5.1” and “GenerateBlocks 1.9.1.
  • Hi Heinz,
    Try to disable your other functions in the child theme first, if that doesn’t work, disable the classic editor plugin to test.
    Feel free to open a new topic and share the login with us.
  • Hi Ying,
    Yes, the classic editor seems to be the problem.
    1.) I installed the “classic editor” plugin.
    2.) I deactivated the classic editor.
    3.) I edit the hook.
    It works fine!
    Thankyou very much.
    :-):)Heinz
Viewing 16 posts - 1 through 16 (of 21 total)
